1 - 6 of 6 Posts
I need your help.
The quickshift of my Brutale not working properly, if decelerating the gear goes in well but if it is the high-rotation does not work.
Has it ever happened to anyone?
Yep the translogic sensors are known to fail. easy to test with a Voltmeter.
Just see continuity or resistance? Do you know the color of the cables?
What's weird is that low-rotation works, if the sensor is really damaged, should it not always work or am I wrong?
Make sure there is NO play in the shift linkage rod (ie make sure the two nuts are completely tight, shift rod cannot move side to side) and that the two ball joints at the end of the shift rod is clean and not stuck.
1 - 6 of 6 Posts
