Hello guys,
It's been 7 months I own my F4. It's a 1000S from 2005. I did lots of update (radiator bracket/ mitch's hub/ manfred fan etc...)
I also purchased and installed adam's chip (decat+RG3 exhaust map).
From the first ride, I smelt unburnt gas and the fuel consumption was high at end summer temp : around 20-25°C (68-77°F).
Fuel light popped up around 190km (118 miles) and several weeks after this ride, I did 207km and it remained 2L of fuel (0.52 US Gallon). Temp was around 10-13°C (55-55°F).
To compare, with my 998 and 4L less in fuel tank, I can do 300-310km (186 miles) fuel tank fully empty
I decided to contact Adam to help me sorting out this consumption problem... Spent months of troubleshooting me and I appreciate a lot ! And I adjusted the trimpot in the ECU couple of times.
The previous week I did 180-186km (111-115 miles) before the light popped up on the dashboard. The weather temp was around 3-5°C (37-41°F)... I decided to go to the gas station and arrived there with 2L left in the tank and I did 206km (i.e 9L/100km or 26 US MPG) ! That's a lot espacially when I don't exceed 6k rpm. The average rev I cruise is 5000-5500 rpm...
I scheduled an maintenance to do some dyno run with AFR to adjust the ECU trimpot. To set it perfectly.
However, I would like to know what is your fuel consumption with your F4 ? I would like a reference point... If possible with Adam's chip.
And last question, what could be the fuel consuption fluctuation in percent between winter and summer temp ?
Thank you in advance.
