I would like to ask you some questions about the motorcycle,
1) the chain makes noise at a low speed because it touches the plastic protector of the swing arm, while it is okay in length it makes noise,how can i repair?
2) the clutch sounds when the engine is running at neutral and when i catch the lever the sound stoped..is it problem?may i repair?
3) I would like to change the slipper clutch with a normal one?can i?
the bike has just 6000km on odo
These for now thank you for the acceptance
Sounds normal to me. It has a semi-wet clutch so it's going to be more noisey than a wet clutch. Chain slap is a function of a chain out of adjustment. If it's still too loud after its adjusted that's normal! Unless you've worn the plastic guides down and its hitting metal....
Read Only
may i change the slider? with something like ruber material?..the trouble comes from the plastic slider
The slider is a rubber material.
