Does anyone have the instructions on how to set one of these up?
I had one originally fitted but it was quite a messy install and simply velcro'd to the top of the instrument cowl.
I removed it but have refitted it with a new custom made bracket and a plug into the main harness.
However I can't set it up. I thought it would be a simple request to PUIG but unfortunately they no, longer make or distribute this part.
There is a small button at the bottom of the unit which I assume will be to set each parameter but I could really use some instructions. Its is identical to a Chronos digital gear indicator but I am advised that looks are the only thing they share in common and the set up procedures re totally different.
Can anyone help??
Can anyone help??
