1 - 11 of 11 Posts
According to the Dynojet website, and the part numbers on the PCIII this one can be used with:
2006-2007 Brutale 910
2002-2006 F4
2004-2005 Brutale
2004-2005 F4 1000
However, I am not sure if they prepare them for a specific model, this one was intended for a 2004 F4 SPR.
http://www.powercommander.com/powercommander/powercommanders.aspx?mk=23&mdl=241&yr=2004&pc=713&mk-n=MV Agusta&mdl-n=F4&pc-ver=411&prod-type=Powercommander III USB&notes=
Retails for $370.
$175 shipped in the lower 48.
Thanks!
Carlos
713 870 6709
They have downloadable maps for all models, easy to install, but a custom map is always the best way to go.
Yours was custom mapped for an SPR? If so, with RG3 pipes and BMC (or other similar type) air cleaner?
$100 plus shipping anywhere you need it shipped takes it. I no longer own an MV so I have no need for it. Thanks.
This one works with the 16M ECU......paired injectors. The 5SM ECU fires injectors sequentially.
So if your 2007 has the older ECU it will work.
Pretty sure you have the 5SM
Would probably work with Ducatis or other bikes with the 16M.....wiring harness would be big difference. (4 Injector connectors, type of connector, length of harness)
1 - 11 of 11 Posts
