thanks, informative! now would you say that a F41000s with a full exhaust and eprom would have the same power as a stock standard 312 RR??
Not exacly, the 312RR1078 has 168 Hp, the 1000S with opened pipes and Eprom stops at 154 Hp.
In case the Eprom is made on the test bench, therefore the map will be the best one for that specific bike, then the S can achieve 159-162 hp, which is still a bit less, but as the engine is not Euro3 due to the timing of the camshats the S (which more "crossed"than those of the 1078), in terms of full speed can be as fast as the 1078 or even more. In addition to what above, the 1078 has a little bit higher torque.
