1 - 13 of 13 Posts
Hi everyone I have the opportunity to buy one PC 111 for my MV Agusta F4 1000 2010 model turns out is a used one and was fitted in one MV Agusta F4 1000 312 R if I’m no wrong do you guys think that will fit on my bike?kind regards
It is fairly universal, I have PC III in my F4 750, and the one your looking at is from a F4 1000 312 R.
They are only a fuel/air piggy back on the ECU, ok but not Brilliant, quite dated now. If your rich and want the best get a Microtec ECU, if poor or don't want to splash the cash have you tried contacting the merc07 here: Free 16M Diagnostic software Email the kindly chap and see if he can help you improve your bike without a PCIII by offering a decent custom map.
The 2010 F4 runs a different ECU. No chip. Eldor I believe. I would check compatibility as the pre 2010 bike ran Magneti Marelli ECUs
Ok buddy ,I’ve been spending some money on the bike ,but at this moment I would like to go for something not very expensive I will try to have a chat with the lad you told me stay safe
Nope, but I need to spell check before I post!
Yes he does although he doesn't say which PC they go up to at least 4.
Hey Mv lover not sure what you want to do with your bike/mapping, but you could try asking Chris at Xbikes incase he can help: X Bikes | Home
Mine runs a Magneti Marelli
So basically what you say is the PC is plugged on the injection system and air box ?
If the opportunity comes I will buy a used one otherwise I will leave it the way it is for now.
Hi ya Mv lover, me I don't know much about the Power commanders, I know their limited, compared to a fully tweaked ECU setup. it depends what you want to do/fix. Before you spend your money try below:
Here is the site for Power Commander V - Power Commander. You could give them a ring and have a chat.
If you want first hand intel with someone here try by re posting your question here the correct place for your model and state what you hope to achieve: F4 - 2nd Gen. 2010+ this way you won't throw money away by buying something that isn't going to do the job well enough. I don't know if your going to need any exhaust modification to go with a PC to get something more rideable which is why it may well be worth posting your question in the best place where the right folks will spot it.
Sorry I couldn't be of more help, to tired to think straight last night.
Thanks MVBERT very kind of you try to help me,the main reason why I want a PC is because I got fitted the SC project exhaust on the bike and honestly the bike works just fine ,although I know that with a PC probably would work better, like I said if I get used one will go for it otherwise I’m live it the way it is,unfortunately as you the pandemic changed the things a bit for everyone,keep safe mate
1 - 13 of 13 Posts
