1 - 2 of 2 Posts
:flash: I am trying to fit the intergrated tail light to my senna...The brake light works...But the indicators only plash once... can`t follow the instructions with regard to the resistor section..Just had my friend who is a BMW trained tech.. and he is not sure..(I think he has stage fright though..not wanting to do any damage) has anyone any ideas....
Kind Regards Carlos..... :cool:
If the flasher or blinkers are LED base then you need to replace the orginal flasher relay to a Narva LED flasher relay, purchase from Repco. $21.00 AUD. Narva Part Number 68249BL (square shape).
The orginal flasher blinker relay was not design to work with LED blinkers.
Don't use the resistor method as the resistors get REALLY HOT very quickly.
1 - 2 of 2 Posts
