1 - 11 of 11 Posts
Hey guys
I've been looking at the different bikes with the 3cyl and I'm curious to know what are the actual physically differences between them (other than the obvious chassis).
I.e. why does the F3 800 make more (advertised) power than the Dragster RR? Is it an ecu thing? Is there physical motor differences (more aggressive cam maybe?). I'm aware of the Euro 4 differences so not really talking about that.
Apologies if this is already discussed elsewhere!
The dragster has steel valves instead of Ti, different springs and cams as well. RR makes its extra power over the STD B3 800 engine by using 6 injectors instead of the STD 3.
And F rev a little higher although not much but about another 300rpm.
Dragster 125 dragster rr 140 although optimistic and 6 injectors as mentioned
F3 800 148bhp
Compression ratio is different, due to different pistons.
Compression ratio, ECU map are likely not the only reasons.
Crankshaft, Piston and associated connection are likely to be lighter on F3 and F4. With a lighter mobile equipment, the engine can reach higher RPM, but is generally having less torque at lower RPM than the engine with heavier mobile equipment.
There are no "B" motors.....
1 - 11 of 11 Posts
