1 - 3 of 3 Posts
Hi guys..
So I've put 1400miles on her already and I'm still trying to figure this mapping out. I've had the PCV fitted with 2 dyno tuned maps (wet & sport.. btw a wet map is a waste of money on a bike with TC) and I'm confused as to how the PCV overrides the factory 2 maps.. I've tried all the combinations and it certainly makes a difference when you run the bike in sport and PCV in wet and vice versa.
btw.. what is the normal map on the 2013 brute... wet?
thanks in advance
The PCV intercepts the stock ECU and delivers its own data (map).
I don't think the standard second map is considered "wet" but a softer option overall.
so is the second standard (softer) map running richer then 'sport mode'?
1 - 3 of 3 Posts
