1 - 3 of 3 Posts
Anybody heard/come accross problems with the PCIII on the F4 1000 ?
Like that it can only map at 500rpm intervals rathers than 250rpm intervals ??
Any ideas why if this is the case ??
Hi Spud,
I,ve had this problem with the 1000R because PC didnt have the map for it and still dont, but this was sorted with a simple fix from PC that rectifies this issue. If you want the fix PM me i,ll send you the file, I dont think there will be a problem if you using it on the 1000S.
regards
al
If you are talking about the rpm issue that is a different situation. The new ECU will show a double rpm compared to the older ecu on the S. A simple patch from DJ will cure this.
As far as mapping in 250rpm increments, just go to the menus in the PC software, select "maximize map resolution" then send map. You'll see that it sets the rpm increments to 250rpm.
1 - 3 of 3 Posts
