I have put together a part number list for the Titanium bolts I have replaced. some of the lengths might vary very slightly compared to your original but this is a close as you can get and they worked ok for me. the top chain slider bolt needs cutting down too.
If there is anything not on the list that you would like to do then let me know and I will get back to you with the answers.
The list is based on natural finish Titanium which is like shiny chrome finish.
You can however have Titanium anodised in a choice of three colours, I went with gold.
The colours available in Titanium are blue, gold, purple and as stated
natural finish, they do charge a small amount for anodising.
If you want a anodised item then all you need to do is as add the first letter of the colour to the end of the part number ie if you want gold front caliper bolts it would be TISC1060FG Or you can simply state the colour you want when you call or email them with the items you want.
I would get a quote first so you know the costs, Titanium is very expensive.
The best thing to do is order a few to begin with to see what you think and then you can always add more as you go along. At least with the list below you can choose which ones you want to do for the bodywork bolts you will also need some M5 Collars so ask them for a selection of collars and plastic washers to go with your bolts.
part numbers for collars are below
LCOLLAR5-7-3U X 20
and
LCOLLAR5-7-5U X 10
Ask them for a selection of plastic washers and also some liquid thread lock would be a good idea.
Hope this is of some use to some people
Dan
FRONT MUDGUARD BOLTS IN TITANIUM TISC615 x 4
MIRROR MOUNTING BOLTS IN TITANIUM TISC625 x 4
REAR HUGGER BOLTS IN TITANIUM TIFB516 x 4
TOP REAR CHAIN GUARD BOLTS IN TITANIUM TIFB516 x 2
LOWER REAR CHAIN GUARD FRONT BOLT IN TITANIUM TIFB516 x 1
LOWER REAR CHAIN GUARD REAR BOLT IN TITANIUM TISC515 x 1
BRAKE LEVER PERCH BOLTS IN TITANIUM TISC625 x 2
CLUTCH LEVER PERCH BOLTS IN TITANIUM TISC625 x 2
FRONT SCREEN BOLTS IN TITANIUM TIFB415 x 8
FRONT FAIRING RH AND LH INNER COVER BOLTS IN TITANIUM TIFB415 x 6
FRONT RH AND LH SIDE FAIRING BOLTS IN TITANIUM TIFB520 x 6
FRONT RH AND LH SIDE FAIRING BOLTS IN TITANIUM TIFB516 x 4
BELLY PAN SIDE BOLTS IN TITANIUM TIFB516 x 5
LOWER BELLY PAN FRONT BOLTS IN TITANIUM TIFB 516 x 2
LOWER REAR BELLY PAN REAR BOLTS IN TITANIUM TIFB520 x 2
FRONT SIDE FAIRINGS INNER TRIM BOLTS IN TITANIUM TIFB415 x 6
FRONT SIDE FAIRINGS INNER TRIM BOLTS IN TITANIUM TIFB510 x 2 HOLDS EXH VALVE CONTROL BOX
FRONT OIL COOLER GUARD BOLTS IN TITANIUM TIFB510 x 2
REAR TAIL SECTION UNDERSHIELD BOLTS IN TITANIUM TIFB510 x 6
REAR SET BOLTS IN TITANIUM TISC820 x 4 REQUIRE THREAD LOCK
REAR PILLION REST BOLTS IN TITANIUM TISC825 x 4 REQUIRE THREAD LOCK
LH REAR SET HEEL GUARD BOLTS IN TITANIUM TISC610 x 2
RH EXHAUST HEAT SHIELD BOLTS IN TITANIUM TIFB510 x 3
FRONT FORK LOWER PINCH BOLTS IN TITANIUM TISC825 x 2
TOP FRONT FORK CLAMP BOLTS IN TITANIUM TISC825 x 3
LOWER FRONT FORK CLAMP BOLTS IN TITANIUM TISC825 x 4
FRONT BRAKE CALIPER MOUNTING BOLTS IN TITANIUM TISC1060F x 4 REQUIRE THREAD LOCK
FRONT BRAKE CALIPER JOINING BOLTS IN TITANIUM TISC840 x 8
FRONT BRAKE CALIPER PAD PINS IN TITANIUM TIPINBP012 x 4
HORN BRACKET BOLTS IN TITANIUM TISC615 x 2
REAR SUBFRAME BOLTS IN TITANIUM TIFB840 x 4
REAR SUBFRAME BOLT (NUTS) IN TITANIUM TINYNFL8 x 4
REAR BRAKE CALIPER MOUNTING BOLTS IN TITANIUM TISC820 x 2 REQUIRE THREAD LOCK
REAR BRAKE CALIPER JOINING BOLT SET IN TITANIUM TISPDUC01-2 x 1
FRONT DISC BOLTS IN TITANIUM TIDISCDUC10 x 10
REAR HUB PINCH BOLTS (CHAIN ADJUSTER) IN TITANIUM TISPMV06 x 2
REAR SPROCKET NUTS IN TITANIUM TISPN8 x 5 REQUIRE THREAD LOCK
FRONT SPROCKET COVER BOLTS IN TITANIUM TISC625 x 3 REQUIRE THREAD LOCK
RH ENGINE COVER BOLTS IN TITANIUM TISC625 x 9
LH ENGINE COVER BOLTS IN TITANIUM TISC620 x 8
GEAR CHANGE ROD BOLTS IN TITANIUM TISC620 x 2
GEAR CHANGE ROD SELECTOR BOLT IN TITANIUM TISC625 x 1
FUEL TANK TOP FRONT BOLTS IN TITANIUM TISC610 x 2
FUEL TANK SIDE MOUNT BOLTS IN TITANIUM TIFB610 x 6
REAR TOP CHAIN SLIDER BOLT IN TITANIUM TIFB630XS x 1 REQUIRES CUTTING SHORTER
REAR LOWER CHAIN SLIDER BOLTS IN TITANIUM TIFB616 x 3
FRONT BRAKE RESEVOIR MOUNT BOLT IN TITANIUM TIHX615 x 1
FRONT BRAKE RESEVOIR MOUNT BOLT (NUT) IN TITANIUM TINYNFL6 x 1
REAR BRAKE MASTER CYLINDER BOLTS IN TITANIUM TIHX620 x 2
REAR BRAKE MASTER CYLINDER BRACKET BOLTS IN TITANIUM TISC615 x 2
REAR ENGINE EARTH BOLT (IN FRONT OF SHOCK) IN TITANIUM TIHX612 x 1
REAR SHOCK ABSORBER TOP NUT IN TITANIUM TINYNFL12FF x 1
TOP FRAME SIDE PLATES BOLT IN TITANIUM TIHX10105F x 1
TOP FRAME SIDE PLATES BOLT (NUT) IN TITANIUM TINYNFL10F x 1
Here is the contact details for Pro-bolt
http://www.pro-bolt.com/
That is quite detailed. Just a question for the uninitiated but the Titanium bolts are for what purpose...losing weight off the bike? Does it make that much of a difference?
They do help with weight loss but there are more cost affective ways, to take weight off the bike.
if you did a complete bike you could loose upto 3 kilograms
The main reasons for me is the look of he Titanium fasteners especially if you have them anodised plus the fact they stay mint forever!
Standard manufactures bolts although MV is better than most will eventually go off colour an maybe even go rusty
