Just bought this 1 for my Dragster from bs-motoparts
Simple enough and won't break the bank like some.
I'm not sure about the S2R Tony, but some Ducati model's axle sizing is the same as MV, and all MV axles are the same if that helps. (43mm if I'm not mistaken) It should be around 42.8 if you ask me.That looks very like the one I already have for my Ducati S2R. So perhaps I just need the adaptor for a 1090.
Google is your friend mate, and my photo album - crikey, do I add all those pictures for no reason.i have never seen, nor used, any Bursig stand in my life... how do you use it Donsy ? does it have to be attached to some special bracket at the chassis ??
i am going to use it for the Trepistonis if they are just need to be plugged..
i see! so they do need special bolts to be replaced at the spot where the bursig should be plugged... Thank you there :f4:Google is your friend mate, and my photo album - crikey, do I add all those pictures for no reason.
It's not the same for all models, but close enough - http://gallery.mvagusta.net/donsy/bursigandothertools/page3/
On some models yes, it's supplied with the stand if it's needed.i see! so they do need special bolts to be replaced at the spot where the bursig should be plugged... Thank you there :f4:
