1 - 2 of 2 Posts
Does anyone know of an aftermarket option for replacing the clutch fluid res/master cylinder? Or good place to quickly get an OEM replacment?
My res was broken off in shipping and I would very much like to ride the bike so any help would be more than appreciated :bawling:
motowheels.com has the brembo radial pump masters in stock....the resovoir is not included and needs to be ordered separately (they have those too).......Also note, the OE nissin master uses a 1.0 pitch banjo bolt, the brembo uses a 1.25 pitch thread bolt. ( or the other way around, i forget).
secondly, the oe master has a clutch switch built into it....you can either bypass (jump the connections on the wires that plug into the oe switch) or get a 1.25 bajo bolt with switch built into it.
lastly. the location of where the clutch line connects between the oe and brembo are different...requiring a new clutch line with a angled end...
the banjo bolt switch and new line can be found at speigler.
1 - 2 of 2 Posts
