1 - 20 of 43 Posts
So, I'm on the verge of selling my boat (never use the darn thing and have someone coming to look at it tonight) and have been enamored with the TV since its conception. I currently have an '08 312R in the garage that is getting quite uncomfortable to ride, but I don't really want to part with it anymore. Now, after hearing all the good news about the TV (non-Lusso), I want to hear some bad news. I've sat on one, but never taken one for a test ride. Seems very comfortable for my 6'3" frame. Not too concerned with the power as I have the F4 for all-out speed. Would like to take a passenger, commute, tour, blah blah blah. Things the F4 isn't built for. Anyway, how does this thing manage its heat? It gets quite hot where I live (115+F in the summer) and the F4 really doesn't like that. What kind of troubles have folks been having with the TV? I've read something about the '16 models having problems that were "solved" for the '17 model year.
Thanks in advance!
And for the record, I'm trying to decide between the TV, Moto Guzzi Griso 8v SE, and Yamaha XSR900. Only real reason the Yam is in the running is that there are no local MV or Guzzi dealerships, they're all a few hours away.
Reactions: Go.Possum
115ºF is hot. TV should manage that whilst moving, get stuck in traffic and there maybe issues. A few weeks ago whilst in the Pyrenees I arrived at some roadworks on the uphill side of a pass (so had been working the engine hard up to that point). The ambient temperature was 90-95ºF, higher than I'm used to in the UK. Within 60 or so seconds the temperature display went red and an exclamation came up on the dash. Luckily the lights changed and and I quickly got on my way and the temperature gauge dropped to a normal level. Despite similar temperatures on the same trip I didn't encounter a scenario where this happened again, though the temp gauge was running just above half way some of the time where normally in the UK it runs just below half.
Would be interested to hear what they did on the 2017 model, and if effective in this regard is it retro fit-able to my 2016 TVL?
Love my Turismo, 'does what it says on the tin' and with a certain panache. For two up touring, so long as you're both, how should I put this... of athletic build... then I it would be fine.
Interesting, so it looks like MVs still can't handle high ambient temps even with half the fairings? I wonder if a swap to Engine Ice or the like would quell some of the scorch. There are some areas here that are notorious for high traffic and terribly timed traffic lights, so commuting on the F4 is sketchy. If I know the light is a long one, I usually shut the bike down while I'm waiting. Luckily motorcycles can filter in CA, so that helps a bit. The last thing I would want is for a brand new TV to over heat and damage itself when there are no dealers that will touch it for a couple hundred miles.
I sadly may need to rethink my choices... Would still like to hear others weigh in on this, though.
Something is not right.
I've ridden my TVL in traffic with ambient temperatures exceeding 90ºF - temperature slider on the dash stayed in 60-70% range.
Granted, we've only had a few hot days here in Colorado so far this year. More hot weather is coming, it will be over 100ºF soon enough. I'll be happy to test and report :)
Glad to see you still hanging around here Nick.
As I said this was an exceptional occurrence. Fan didn't seem to be able to make up the difference in airflow. Was already running hotter than usual, probably around 70%, due to incline, riding hard and ambient temperature.
My TVL is in for it's 9000 mile service next week. I'll mention this to the technician. Alps tour early next month so might encounter a similar situation.
I have switched off when stuck at long stop lights before. Have heard that using the kill switch for this is inadvisable, will raise this in another post while I'm thinking of it, though with a tank bag covering the ignition it's my only option.
I live in Las Vegas and the summers are hot, 100+ everyday. Last summer I was having overheating issues. The dealer replaced the radiator and so far so good. Keep in mind this is my daily driver and I deal with traffic on my commute. So this bike have already commute on 105 degrees days with no issues.
If you were at an high altitude maybe the thinner air caused a problem. I have ridden in France in 36c last year and although the engine temp was high and the fans whirled away it never gave a warning sign on the dash. That said I would rather not commute on an TV in constantly high temps.
I see you are looking at the Guzzi 8v engine. I had a 1200 Sport when living in Oz. The few times I had to ride in Sydney and it was hot weather meant the engine heat was very high. If you have long legs your knees could cook on the engine!
My TVRC is 2017 model, in Dubrovnik temp now are from 28 - 31*C, if i am driving "touristic" on open road and suddenly need to stop on road work or long traffic lights temp will rise 70% and fan will cool it down but needs time, but if i am driving "sport mode" 9000 - 11000 rpm for a half hour and then need to stop for a long traffic light temp will rise 80% and fan will run for ages!! Also if you are commuting in city from one traffic light to another for some time fan will run all the time, i share opinion with Bumpkin that fan is insufficient, but it will cool down just need more time. I never have exclamation mark for overheat engine so....
J-Spec, the bike is f..... awesome, piece of art, light, agile and comfy for long distance, will not talk about speed since you are driving F4 ;-))
That's a good point, was on the way up to Col du Tourmalet (2115m) if I recall. Not that near the top though. Haven't seen that error before or since. Like zzaraxx I have seen a lot of fan running when in traffic and in those situations it manages the temperature OK though gauge does run quite high, even in the UK. Much the same as my VFR with it's side mounted rads, in traffic or sub 30mph the fans run constantly as there's virtually no air flow.
Maybe the TV would benefit from a more efficient fan? Will ask dealer if there are any coolants that would have a significant effect on this issue.
Thanks all for the responses! You're making me feel a little better about the TV. Haha. My F4 has the Muzzys metal fan blades, upgraded water pump, and engine ice and it still runs hot. Then again, it's an F4...
I'm considering it more and more, especially since there's a brand new red and silver '16 going for $9,999 at one of the nearby dealers. And in the pics it has a center stand, so is it a Lusso? I'd prefer a white one, but there are none around. Might have to make a phone call today.
Randy, I couldn't leave you guys. We've been through so much! :)
That's a great price. With a centre stand it could be an Edition 1 which is the base model but with included sat nav, heated grips, panniers and the centre stand. Though I would expect an Edition 1 to be 2015, not 2016 unless it sat in the dealers showroom and was a late registration (not too sure how that works on your side of the pond). The Lusso can be identified from afar by the fact that it has a section of the front mudguard, near to the fork, painted in the same colour as the tank and fairing with the rest of it being black.
In the UK at least the Lusso price does not include the panniers, these are extra but as my dealer pointed out as everyone wanted them he ordered each one with the panniers included.
I guess this would be a Lusso, then. Unless they have the pictures mixed up with a different bike.
2016 MV Agusta Turismo Veloce 800 Stock: | Munroe Motors
I'm not really sure how the late registration thing works, either, I'm afraid. Lived abroad for too long to know how a lot of this stuff works. :D
And If this is a Lusso and doesn't come with the panniers, I won't be upset. I have a set of soft luggage that isn't going to set me back another $1,400. And I don't mind wearing a backpack for shorter jaunts, I have a couple nice, motorcycle-focused ones from Ogio and Dainese.
Time for a phone call, I suppose.
We run engine ice in our KTM's for racing and it works great. It is advisable by some to change out the ice in the winter to a fluid that has anti-corrosive properties. Engine Ice does not have anti corrosive additives.
My bike feels hot at an intersection with the temps above 90, but most bikes do.
Discussion Starter #16
So, those are just some stock photos they had, the bike for sale is not a Lusso, but it is the standard red and silver. The guy that came and looked at my boat last night wants to take it out on the lake tomorrow evening, so we'll see how that goes. Sounds like he's going to buy it. May be headed down to San Francisco this weekend to take this TV for a ride.
While you are at the dealership , you may want to ask them about parts. My understanding is that right now, there are no parts at the MV Augusta USA warehoue for this bike. All parts are coming from Italy. And they either don't have them - or something. The quickshifter and cruise control on my bike has never worked in 18 months of ownership . The turn signals , we are waiting on the third set . They have not worked for longer periods than they have worked. And it's a three months wait for them. If something major breaks - at least in my situation the riding season will be over for the MV because of lack of parts. This is totally unacceptable in this day and age.
What aggravation are you prepared to put up with - because it will come.
While you are at the dealership , you may want to ask them about parts. My understanding is that right now, there are no parts at the MV Augusta USA warehoue for this bike. All parts are coming from Italy. And they either don't have them - or something. The quickshifter and cruise control on bike have never worked in 18 months of ownership . The turn signals , we are waiting on the third set . They have not worked for longer periods than they have worked. And it's a three months wait for them. If something major breaks - at least in my situation the riding season will be over for the MV because of lack of parts. This is totally unacceptable in this day and age.
What dealer is telling you this about the parts shortage and has been unable to get parts support for you?
Also, the link referenced above for the TV is a used bike with new tires per the listing
"2016 MV Agusta Turismo Veloce 800
Up for grabs, our rockin' MV touring bike! I've had the pleasure of doing some epic all day high mile rides on the amazing back roads we have. This thing is a total hoot! Comfy as well. It, of course, has been professionally maintained and has fresh tires. If you're looking for the best deal on an MV, well, you've found it!!"
"What dealer is telling you this about the parts shortage and has been unable to get parts support for you?"
Blackfoot Motorsports . Calgary AB.
Are you suggesting this is not the case .
Over the past winter when trying to get parts under warranty , and not seeming to get anywhere with the dealership , I phoned MV USA 4 times over a two month period , and got absolutely no where- a lot of promises I'll do this , I'll do that , but nothing. And now I'm in the same situation all over again
1 - 20 of 43 Posts
