Hello,
On my Brutale 750S it happened this evening the following:
This is how it looks now: IMG 0045
What is your opinion on this? Could be the oil sensor failing or it might be something more concerning? On visual inspection it seems that the oil sensor is a bit oily on the outside.
Thank you!
- on a returning home ride, out of the blue I saw a slight irregular blink of the oil sensor
- I've immediately stopped, visually inspected the engine (all good), looked at oil level with engine stopped (all good), looked at oil level when engine running (all good - the oil was pumped in the engine)
- on starting the engine again, everything ok
- somewhere a bit later the irregular blinking started again then stopped a few moments later
- everything ok till almost reaching home when blinking started again (now in a more regular way - see attached video)
Thank you!
