1 - 2 of 2 Posts
I need to top up my 2006 910 brutale, can i use JASO MA-2 oil instead of just MA ?
I have bought Castrol power 1 4T fully synthetic 10w-50 which JASO MA-2 but the owners manual says MA ?
The MA-2 is formulated for bikes with catalytic convertors...and also happens to have better friction characteristics...at any rate, OK for your MV
Here's an article I copied that explains it:
New JASO oil standards (MA1, MA2):
JASO effectively added the JASO-MA2 & JASO-MA1 specifications by splitting the existing JASO-MA spec into two groups by friction-performance (MA1 is the lower friction oils; MA2 the higher friction oils suitable for bikes).
The change came out as final/approved in 2006 in response to catalytic converters becoming widespread in bikes (EPA/EU requirements); it was also prompted in part by the car-lobby of the JASO organization wanting to specify a subset of the JASO-MA oils for use in their cars (the low friction oils, which become JASO-MA1). JASO-MA2 is just starting to show up in the US Market as a rating because this is the first year that catalytic converter-equipped bikes are widespread.
Aside from splitting the MA spec into two sub-groups, the new specs add a phosphorous content ceiling (better protect catalytic converters by using less, but phosphorous is also anti-wear additive, so it could be less start-up protection). JASO-MA2 being the heavier friction oils most suitable for motorcycle use will become the common standard for Japanese-built (and many Euro-built) motorcycles for the '08 and later model years.
Note that JASO-MA2 can now be API SJ formulated, but API SL & API SM formulations still directly contradict JASO-MA/MA1/MA2 standards because of the use of friction modifiers that are not wet-clutch compatible.
The JASO-MA (no suffix number) still remains in effect as well. For the Kats, API SF/SG + JASO-MA rated oils will remain the oils of choice until they are no longer available.
1 - 2 of 2 Posts
