Hi guys....been a while since I posted on here...which is indicative of how little riding I have done unfortunately!
The F4 sprang a leak from the rad last year while at the NW200 races and after putting off the repair for months, West Mercia Radiators have performed a sterling job on cleaning, repairing, testing and painting the rad and oil cooler (preventative) ready for reassembly. Now, as I have also removed the oil cooler, I am replacing the oil (and filter) so my question is, as ther is virtually no residual oil in the system is there a relay I can remove so I can crank the engine over to build oil pressure without it starting? I was thinking the fuel pump relay?
Thanks for your help!
Gavin
Yep...that would work...or the fuel pump fuse.
It won't take very long to fill the passages.
What year F4 2012 or 2014? I think the fuse numbers are different ?
Thanks both...its a 2012 MY (but on a '14 plate, just to confuse the conversation!). Would be good to know which fuse it is if you are able to let me know...
Thanks!
