Attached is a photo of where I have developed a severe oil leak. It was a small spot on the ground when I went to ride it home from work. About the size of a charge card. When I returned home It started to drip and not stop. :bawling: The oil is seeping out just above the bolt in the center of the photo. Has anybody seen this before? I`m calling my dealer tomarrow. It`s still under warrentee. :bawling: :green:
In my panic I checked the larger of the two and not the smaller one to the left, because I just checked it after reading your post.And it was loose. is there a gasket behind there that may be shot now if it still leaks?
OK OK after the rench I degreesed it and blew it clean with air and wiped it down. And ran it up to temp without spilling a drop.
John Your a friken genious :drummer: somesimes it`s the simple things :silly: The next time i`m at cliffs lunch is on me bro :friday: Thank you,Chris :laughing:
