1 - 2 of 2 Posts
I have a question guys. I just had my first service [1000km] done and now after that, I have an oil control lamp issue. At idle and up tp 3000rpm the lamp goes on, faster than 3000rpm lamp goes of again? oil level seems fine, because lamp goes of over 3000rpm!
Anyway I check the oil level, even put some extra, just to make sure, but the problem of the lamp stayed......
Maybe a little electric bug? Before the service it was running without any problem.....thank you guys!!
I could be the oil pressure sending unit, but i am not entirely certian how to diagnose that. I would bring the bike to the dealer, if it is the oil pressure switch its a cheap fix (in comparison with say an oil pump or a destroyed motor), but if you are in fact loosing oil pressure its not worth the risk of running the bike and potentialy damaging the engine.
1 - 2 of 2 Posts
