1 - 16 of 16 Posts
Hi guys,
Can someone please tell me if oil in this area is normal? When I wipe it away it seeps back in again to the little hole qute quickly (within a few seconds).
Thanks.
Cool. Thanks Donsy. Much appreciated.
Now all i need to do is repair the water pump drain bolt...i managed to somehow strip the threads in the drain hole and now the bolt won't tighten in it. Any ideas?
Thanks Noel. Is there such small HeliCoil for such small holes? Won't be able to get them locally. Sods law that it's the first good weather weekend?
Any other ideas how to plug it quickly, temporarily?
Heli-coils are available down to 4mm I think. 6mm for sure.
You could always find an alternate bolt and sealing washer a size larger and tap the hole to match.
It's an M8x1.25 if i'm not mistaken.
Will order some HeliCoils just to have but meantime will look at tapping to slightly bigger and see if i can get a seal to enjoy the bike this weekend.
Thanks esq'z me.
Wishing you all a good weekend.
Hmmm...the water pump drain on my bikes are M6 x1.0. Not much room to go a lot larger. Good luck.
I had a look on star twin trading and on the water pump drawing it is item 14 (for my F4 750).
And yes it doesn't look like there's much room for going much bigger.
Sods law this would happen right before the best weekend of the year so far!!
Will need to spend sometime on it tonight and see what i can do.
Really?
HeliCoils go down to M2x0.4
Take a longer Allen head bolt put it through from the inside, put a washer and nut on
the outside and tighten, it'll seal
Make sure the head is lower than the tapered area where the impeller turns
It will fit on the HO Factory pump I checked
:popcorn:
Thanks Noel. Have ordered bunch of helicoils to have around. Meantime did this (not pretty but no leaks) and also used some flange sealant making sure nothing was loose or protruding on the inside where the impeller is. It is tight , i tested it but just don't know if it'll tighten again if i have to loosen to drain. Will most likely order a new housing from Alex and possibly repair this one later. The screw i put in is a little bigger in diameter hence it went in tight. Thanks for all your help.
Donsy, that's very kind. I can't accept just to pay postage. If we can agree the one i damaged is the housing that comes with the uprated impeller .... I think it's slightly different to the stock one.
Either way i greatly appreciate your kindness but will pay you for it + p&p.
Thanks, Donsy
Thanks, Donsy
I'll have a look sometime today and let you pick mate.:)
Wrong tip Donsy .......that one is for changing impellers
Pump seals are on page B68 of the Engine Manual
:popcorn:
Yes Noel.
Which version of which manual ?:popcorn:
The picture is also in my photo album. http://gallery.mvagusta.net/donsy/cooling/
Are you my newly appointed editor, seems like you're just going through my posts to see if I've said or done something wrong somewhere.:stickpoke Either way, thanks.
1 - 16 of 16 Posts
