1 - 11 of 11 Posts
King of the Sink
For the life of me, I can't remove the oil filler plug on the 910R!
As I normally do when I work on things mechanical, I made sure that I could get to everything and loosen things I needed to remove later. The sump plug was very tight, but I managed to undo it - but I can't budge the top plug (see pic below).
Does anyone have any ideas/hints/tips? Does the engine have to be hot in order for the plug to loosen etc.?
Thanks in advance!
Make sure you have the hex fully inserted. Don't try to apply steady pressure, instead give a few jolts to break it loose. If I remember correctly mine was tight. I had warmed up the engine before draining the oil but it wasn't very hot by the time I pulled the filler plug.
King of the Sink
Thanks Koop. I did have the hex fully inserted, but I'll give the jolting a try.
use the hex, if you cant undo it by hand, put a closed wrench small enough to catch the end of the hex on it, this will give you more leverage, sort of like a breaker bar kinda. I use tools all the times, those hex wrenches can be a pain. Next time save yourself the trouble and buy a set of T handle hex wrenches or a socket set of hexes with the ratchet.
I use sockets from snap-on so can fit all the usual bars and ratchets to them. Also you can then use an impact wrench to give it a jolt ans save the nut. Bit too far for a run to try mine?
King of the Sink
Thanks guys.
That depends john348 - where are you? :)
King of the Sink
I'm on the way! It should have worked itself loose by the time I get there! :)
1 - 11 of 11 Posts
