1 - 2 of 2 Posts
Hey all,
I am not seeing much info on removing the oil cooler for the oil change ..... level of importance? Anything need replacing O-rings etc?
Removal involves mounting points that have bolts that can be accessed from the right side of bike with fairings removed. The hoses are held in place with bracket that has three bolts at engine.
The oil cooler should be drained because it holds residual oil and traps debris. Have orings on hand in case they need replacing. I've reused them though depending on damage from heat or installation.
1 - 2 of 2 Posts
