1 - 11 of 11 Posts
Just servicing my Brutale 920, 3 Liters came out, but 4 Liters went in??? :surprise:.
Sorry if this topic been covered, but couldn't find anything concrete.
So whats the official oil capacity on a 920?
Manual for the 990R says to fill with 3Kg oil and then close cap, run engine, wait 10 minutes then check level and top off to Max line. Couldn't find a 920 manual.
Where is your level in the glass after running the bike and then checking the oil level after 10 minutes of rest?
It was above the top line, but that was on a stand and on uneven ground, will try again later.
But surely shouldn't be that much discrepancy, its a whole liter.
If the bike doesn't pour oils out, surely more oil would be better?
Too much oil is NOT a good thing for a variety of reasons.
Primarily increased crankcase pressures and the probability of oil venting into the air box and then making a mess of the filter, leaking out onto the engine/chassis, and going through the combustion chamber (carbon build up and damage to catalyzer if still installed).
Keep it at or slightly below the top line...as checked vertical on level ground after 10 minutes of rest.
Thanks all for the tip.
Will do.
Why, oh, why does this always come up?????
On every model, with most newbies.......THINK, IT HAS A SIGHT GLASS
THE BIKE MUST BE VERTICAL AND LEVEL, OR IT WON'T WORK
Put oil in the damn thing till it shows on the sight glass, put the filler plug back in and start it and let it run for a few seconds........you just filled the filter
Now top it off to the line.......simple isn't it?
I have no idea how much oil my bikes or cars need, whether they have a dip stick or sight glass.......I buy oil by the gallon:grin2:
Ed;
Over filling the crankcase doesn't increase crankcase pressure......ITS VENTED
Filling it until the crank can hit it, foams it and makes a giant mess
Yes, crankcases are vented.... and yet the pumping of the pistons along with compression blow-by past the rings causes a positive pressure (reasons for the venting). Since air is much more compressible than oil, and a higher oil level decreases the volume of air inside the crankcases, effective pressure is increased ....which is why the engine will push oil out the breather until it gets back to the proper level for balance.
Noel, you know all that. Why do you have to be so argumentative? And, yes, crankshaft frothing up the oil is another point....but most modern engines carry the oil so low that the crank wheels rarely come into contact with the sump oil.
Ed;
There is no pumping of the pistons on a 4 cylinder MV.....they go up and down in pairs .....the volume doesn't change
The difference in compressabilty means nothing and it's vented to atmospheric, pressure stays the same
My El Camino has a 7.5 liter motor and a smaller breather than the MV, it doesn't blow oil
My Aprilia RSVR blows a bit of oil.......it has a dry sump......I fixed the breather
Still pumps...that is why the more recent high rpm engines have started incorporated venting holes in the crankcase between the cylinders, to help with the equalization of pressure. Stop thinking in terms of 7000 rpm red line engines.
Here is an example from a new model update bulletin where venting holes were enlarged for improved performance.
1 - 11 of 11 Posts
