THIS FORKS WILL LOOK REALLY NICE ON OUR MVS:mouthwate:mouthwate:mouthwate WILL IT FIT OR WE NEED A NEW TRIPLE CLAMP:smoking:
They will NOT work....send them to me and I will give you 20 bucks, that is the scrap metal value.
Amazing aren't they?
New triple clamps required. You will need to fabricate a set of brackets to mount your front guard and make an axle and spacers for the wheel. Then source Brembo monoblocks with 108mm mounting holes (Standard on the Marzocci is 100mm) and some nice narrow band Brembo rotors to go with it them you are good to go. Easy.
Give Eraldo Ferracci a call, they did this on their 2007 FBF Superbike, it can be done.
They Just Look Fancy....and Too Expensive
Those bikes they bulid on Discovery Channels "American Chopper" are fancy and too expensive, don't they go for around $150,000?
F$%k that.
The forks are priced about right for the limited production runs each year and the research and development behind them.
Oh well, duck and cover.:later:
