Yea going the system change is another entire approach. It’s a project in itself. Tossing money in this range should be mapped out first. @silentservice703 has it right of course, if your oem is avail install again.
Don't rush to snap photos. I can live with the wait!😂I try to get up to snap a few photos to help visualize. Bare with me…
I'll restore it tomorrow afternoon and see what happens. Will update you all 👍Um, before you go shooting money at it, restore the system to original and see if it works if I dies not work in original configuration, then the issue is downstream of the slave.
Levers are standard nissinDid you change levers?
That's a good suggestion, I will take a look today when I get back from work 👍I believe you said you disassembled and cleaned the master cylinder.... Perhaps the problem is there. You can have a piston cup that isn't sealing inside and not see or have any leakage.
The piston moves back and forth but doesn't produce significant pressure when pushing fluid against the slave cylinder piston and clutch springs.
I'll check when I strip the master cylinder today though it's unlikely, but things like this do happenCould you have reversed a seal during your cleaning?
That's a great idea mitchy. I'll get that sorted ont this weekend and let you know. Thanks 👍Before you spend any more money let's test the master cylinder.
Find a bolt that is the same thread as the master cylinder banjo bolt.
Cut the bolt so it's 1/2 inch long. Add a copper washer to the bolt, screw it into the master cylinder and tighten. Plenty of rags around the banjo.
Bleed the master cylinder by pulling the lever, open and close the bolt, 3 or 4 times, the clutch lever should be hard with No movement at all. If it is still soft or creeps down re-kit the master cylinder or buy a new one.
I did just as you said Mitchy and found that I was loosing pressure in the lever somewhere. So striped it all and found the smallest hole in one of the piston seals.Before you spend any more money let's test the master cylinder.
I haven't had any time to get it sorted out. It's all together but no the to bleed and test it.Glad you found it. My enough to drive you nuts.
My rear brake just lost pressure today. Grrr
