Hi Guys,
I have a slight issue with my clutch and thought I would ask to see if anyone could suggest a reason for it.
So I changed my slave for an Oberon and now I have no clutch, if looks like the piston doesn't move enough to push enough of the rod to open the clutch.
I have bled the master over a 20 times and have no bubbles at all in the bleed tube.
The only things I can think of are:
The master cylinder is loosing pressure as a full pull of the lever (to the grip) is only 2.1mm of movement.
There is air or something in the lines (though I have a new slave and I have cleaned out the master)?
The Oberon slave needs a bigger piston that the Nissin 1/2 inch has to move more fluid?
I firstly bled the air from the system which didn't work. I then took the master cylinder apart and checked the seals, cleaned the parts and put back together. Then bled with more new fluid again, prefilling with a syringe from both ends and prefilling the slave before mounting.
When I pump the lever I get good pressure, I open the bleed port and close before letting the lever out......this lever release has no pressure and is very slow to return to its resting position.
Maybe a nice new set of brembo levers are needed
I'm sure I've missed something.
I did try avoiding the garage for a couple of days to see if that would work, I think the Christmas elves were busy doing other things and didn't want to fix it for me.
Over to you guys for suggestions please.
Si
Si
