Hello, I'm new to the forum and was wondering whether anyone has any advice on fitting the NRC tail tidy / fender eliminator to an F3. It arrived without any fitting instructions and I'm at a loss! Thanks
Didn't realise they had an instructions section on their site - doesn't seem to show up on the mobile version of the site. Sadly they don't have the instructions for this item! Thanks anyway.Tried their website ?
http://www.newragecycles.com/Instructions_s/1862.htm
I'm starting to doubt it. Just can't see how it can be fitted. Have asked the supplier to email me instructions.are you sure that is the right model? No idea how that's supposed to fit the F3
Agree with you Spark. I installed this unit on my 675 RC and had to make some mods to it as well. I made a small plate out of 1/8" aluminum that fit on top of the brace that the original tail bolts to, drilled and tapped each corner to match the original tail bolts and drilled and tapped for the NRC bolt in the exact center of the plate (I think this bolt is 1/4"-20-don't know why they couldn't stay metric). Used the original bolts to bolt this plate in place on top of the brace. No nut or washer now needed for the center bolt. Also made a small L-bracket that is screwed to the back of the left LED plexi and is designed so that a fairing screw will retain the other end, keeping the unit from rotating. Left the tape on of course so disassembly would not be a pain. I also flipped the plate holder around (NRC logo facing forward) so the plate was not at such an extreme angle. On the electrical side, this unit caused a fast flash in the turn signals. Replaced the flasher unit with a $8.95 LF1-S-FLAT solid state flasher unit from superbrightleds.com (plug & play, same connector). This unit doesn't care what kind of lamps you have - 90 flashes/min always. Looks great and has been reliable so far, just not well engineered as you said Spark.I have this tail tidy and it needs some refinement in my opinion. You see the single large hole in the triangular frame? That's for a single bolt to hold the entire piece in place on the frame where the old stock one was. How difficult would it be for them to punch 2 holes out instead and help keep it in place?
On the other side of the triangular piece they have some sticky tape or whatever to help hold it in place. This is stupid in my opinion because those will then cover part of the rear fairing. Should you ever need to take the fairing off? Well they obviously didn't think that far. Leave the pieces of tape/cover on; do not peel them off.
Overall I like the look of the tidy, but NRC just half-assed the production of this unit.
It does?!@tweakbz: Your bike has a CANBUS
That LED headlight equalizer is for vehicles that have CANBUS electronics.
It is NOT a CANBUS.
The technology, if you read the write up in the link you posted, prevents flicker from load differences in the headlight.
