2002 Suzuki GSX-R 1000k2
$8000
I bought this bike new in 2005 as a 3 year hold over.
Current mileage is 23,6xx
This bike has many bolt-ons but has never been opened up, engine is all original and still running original clutch.
New Yuasa battery May of ‘21 (only the 3rd battery ever)
PowerCommander 3USB with multi map switch and quick shifter (Dyno tuned 164hp & 75tq to wheel)
Vortex rearsets (reverse shift pattern)
Bmc air filter
Drivin steel rear sprocket
DID chain (520 kit)
Smog plates
CRG levers
GPR steering stabilizer
Real Carbon fiber ram air tubes
Integrated rear brake/turn light
Flush mount front turn signals
Bar end turn signals
M4 exhaust can
Factory titanium header
Hinson slipper clutch still new in box
OZ Forged aluminum wheels
HH sintered brake pads
Galfer Suberbike stainless brake lines
Samco coolant hoses
Ohlins heavy weight fork oil
Bridgestone RS10 tires May ‘21
Rear seat cowl
Rear seat and rear passenger pegs
New old stock front faring ‘20
NGK plugs(not sure when)
Battery tender wired
Radiator is water and additive only (no coolant)
I have some parts still in a box and I’m sure I’m missing some things.
The only bad is a few scratches, tank from coat zipper, side fairings from normal use.
This bike will still out perform new 600’s, 750’s and more.
This is a bike from a time before traction control and ABS.
I’d say this is not a bike for beginners however this was my first bike so it can be done safely.
Thanks for looking
$8000
Bmc air filter
DID chain (520 kit)
Smog plates
CRG levers
M4 exhaust can
Samco coolant hoses
Rear seat cowl
Thanks for looking
