Hey I just joined this forum and sorry my first post is a help thread but I just bought an 08 312 and installed the MV brand NIWI . I didnt replace the impeller shaft seal and after the install I noticed coolant in my oil and the leak from the weep hole . Did I screw up big time or can I just change the seal and give it a fresh oil change . Thanks for any help
Im not sure if its because the NIWI creates more pressure and the seal couldn't hold but during the install I didn't mess with the seal , I just unscrewed the impeller from the shaft and put the new one on
I'd say change the seal and change the oil. It should be fine as long as you stop the leak.
Oh........ and welcome to the forum :yo:
I changed both seals and all the O-rings on the water pump , changed out the oil and filter and everything is good NO LEAKS :yo: :f4:
Awesome :drummer:
