1 - 2 of 2 Posts
I saw someone on this forum upgrade banjo and brake line for their nissin, what is banjo size that go with regular speigler brake line?
banjo size?
Phil;
i'm assuming you mean banjo BOLT size......
almost all a 10mm.....you used to be able to get 8mm ones
now comes the thread size......i have Nissin M/Cs on my Brutale with Brembo calipers
the F4 has PVM M/Cs and Brembo calipers
Brembo Calipers use M10 X 1.25 mounting bolts (Japanese thread)
standard DIN is M10 X 1.5
BUT, they USUALLY use M10 X 1.0 banjo bolts......European thread
most Japanese hydraulic stuff is M10 X 1.25
the 8mm banjo bolts are M8 X 1.0
if you don't have a thread gauge.....
use 2 standard bolts.....
an M6 X 1.0 and a M8 X 1.25
1 - 2 of 2 Posts
