The factory has recently changed water pump makeup so we should have seen the last of this. The new seals can also be retrofitted to all bikes. I will clarify the part numbers before including them, just now heard the details.
Please reply or email me or the FAQ if you run into a leak. Please also, because I promise you I will ask you anway, make sure that you are looking at an actual water pump leak before reporting one and not just overflow from the reservoir. See the FAQ for details.
yeah I have the dreaded leak, drip drip drip from the water pump housing - interestingly there is a tiny hole which the blue fluid is coming from - I'll contact Cliff's and mention it to arrange for a warrenty repair.
