1261 - 1277 of 1277 Posts
Site Sponsor
Discussion Starter #1,261
MV Agusta Carbon Fibre Monocoque Front Rim
Carbon fibre monocoque front rim. Glossy finish with red weft. Extremely light, only 4.95 kg per pair. The extreme lightness gives the bike better manoeuvrability and a sportier set-up, with an increase in performance both in acceleration and braking, giving the rider a greater feeling of safety and comfort. Dimensions: 3.50 x 17". Weight: 2550 grams. Approval valid for road and track according to DOT-E & JWL standards.
484045
https://evolutionbike.it/mvagustastore/mv-agusta-carbon-fibre-monocoque-front-rim.html
Site Sponsor
Discussion Starter #1,262
QD Exhaust B3 Y16/DRagster Y18 Power Gun Silencers
The QD exhaust system “POWER GUN” Series, uses the stock header-pipes. The exhaust system is created with a rockwool muffler and it is compatible with the original catalyst-converter. The three “dragster style” end-caps are in machine-worked anodized Ergal. The exhaust system is created with specific volumes and passages, that give to the motorcycle the best performance result and an agressive voice. The kit includes all the brackets and illustrated instructions for an easy fitment. The exhaust system is Euro 4 homologated. The horsepower gain is about 2,5 HP. For Dragster Y17: Euro 4 included. Free shipping worldwide for this item.
484058
https://evolutionbike.it/mvagustastore/qd-exhaust-b3-y16-dragster-y18-power-gun-silencers.html
Site Sponsor
Discussion Starter #1,263
QD Exhaust B3 Y16/Dragster Y18 Black Power Gun Silencers
The QD exhaust system Power-Gun Series, uses the stock header-pipes. The exhaust system is created with a rockwool muffler and it is compatible with the original catalyst-converter. The three “dragster style” end-caps are in machine-worked anodized Ergal. The exhaust system is created with specific volumes and passages, that give to the motorcycle the best performance result and an aggressive voice. The kit includes all the brackets and illustrated instructions for an easy fitment. The exhaust system is Euro 4 homologated. The horsepower gain is about 2,5 HP. For Dragster Y17: Euro 4 included. Free shipping worldwide for this item.
484092
https://evolutionbike.it/mvagustastore/qd-exhaust-b3-y16-dragster-y18-black-power-gun-silencers.html
Site Sponsor
Discussion Starter #1,264
CNC Racing Right Handlebar Switch (street use)
The switch body is machined from full 7075 aluminium (Ergal) bars and has then undergone a hard black anodizing process that enhances processing with CNC machinery. All the buttons compliant with the IP67 military standard that certifies the switch itself is water resistant. The operation of all buttons is guaranteed by over 700,000 cycles. Assembly is very easy and plug&play: just dismantle the original switch with the tools recommended by the Manufacturer; then fit the CNC Racing switch connecting the plug to the bike original cable. Nothing else is required and you can always go back to the original configuration without any modification.
484132
https://evolutionbike.it/mvagustastore/cnc-racing-right-handlebar-switch-street-use.html
Site Sponsor
Discussion Starter #1,265
CNC Racing Left Handlebar Switch (street use)
The switch body is machined from full 7075 aluminium (Ergal) bars and has then undergone a hard black anodizing process that enhances processing with CNC machinery. All the buttons compliant with the IP67 military standard that certifies the switch itself is water resistant. The operation of all buttons is guaranteed by over 700,000 cycles. Assembly is very easy and plug&play: just dismantle the original switch with the tools recommended by the Manufacturer and the master cylinder clamp; then fit the CNC Racing switch connecting the plug to the bike original cable. Nothing else is required and you can always go back to the original configuration without any modification.
484146
https://evolutionbike.it/mvagustastore/cnc-racing-left-handlebar-switch-street-use.html
Site Sponsor
Discussion Starter #1,266
Site Sponsor
Discussion Starter #1,267
EvolutionBike B3/Dragster Quick Shifter Kit
Ultra-durable Quickshifter sensors, designed to perform, produced from special stainless steel alloys. Environmentally endurance passed. The #1 OEM choice for reliability and performance. It works in upshift and downshift. Ideal as a replacement for OEM 2.0 quickshifter or, as for Serie Rosso standard models, to get the possibility to change without clutch. Completely plug and play. For Serie Rosso standard models it's necessary to upload the map with Texa tool.
484192
https://evolutionbike.it/mvagustastore/evolutionbike-b3-dragster-quick-shifter-kit.html
View attachment 484192 https://evolutionbike.it/mvagustastore/evolutionbike-b3-dragster-quick-shifter-kit.html
Does that fits on a 2014 Brutale 1090R? What do you advice for quick shifters for this model?
Site Sponsor
Discussion Starter #1,269
Site Sponsor
Discussion Starter #1,270
MV Agusta B3/Dragster Racing Rearsets
Adjustable footrests set. Entirely made of Ergal 7075 T5. Reclining footrests machined to offer greater grip. Adjustable and lightened gear lever. Adjustable footplates that allow 6 to 9 different footplate positions allowing you to find the best set-up for your driving style. The kit includes the Titanium flaps and all the screws necessary for assembly.
484341
https://evolutionbike.it/mvagustastore/mv-agusta-b3-dragster-racing-rearsets.html
Site Sponsor
Discussion Starter #1,271
Site Sponsor
Discussion Starter #1,272
CNC Racing Cush Drive Hub Flange
Cush drive hub flange made in light alloy and machined from solid with following surface anodizing. No modifications required to replace the factory flange, using the stock mount rubbers. Check in the related products the combination of the kit available.
484420
Site Sponsor
Discussion Starter #1,273
CNC Racing Cush Drive Hub Flange Y18
484433
