1081 - 1100 of 1222 Posts
Site Sponsor
Discussion Starter #1,081
MV Agusta Corse B3/Dragster RR Carbon Key Guard
Compatible with: B3 Y16-->Y19 RR, Dragster Y18-->Y19 RR.
Key guard in carbon fiber.
Produced in autoclave, a process that applies different thermal cycles so that temperature and pressure are distributed evenly, ensuring the production.
Personalized with MV Agusta Corse logo.
Site Sponsor
Discussion Starter #1,082
MV Agusta Corse B3 Y16 Carbon Underseat (high
MV Agusta Corse B3 Y16 Carbon Underseat (high)
Upper underseat in carbon fiber.
Site Sponsor
Discussion Starter #1,083
MV Agusta Corse B3 Y16/Dragster Y18 Carbon Exhaust Cover
Compatible with: B3 Y16-->Y19, Dragster Y17 Euro 4-->Y19.
Exhaust cover in carbon fiber.
Site Sponsor
Discussion Starter #1,084
MV Agusta Corse B3 Y16/Dragster Y18 Carbon Right Manifold Guards
Compatible with: B3 RR Y16-->Y19, Dragster RR Y17 Euro 4-->Y19.
Right and Left manifold guards in carbon fiber.
Personalized with MV Agusta logo.
Site Sponsor
Discussion Starter #1,087
MV Agusta Corse Fluid Reservoir Rear Brake Cap
Compatible with: all MV Agusta models.
Rear brake fluid reservoir cap made from light alloy solid with red surface anodising.
The kit includes all the screws for the application.
Assembly is simple and does not require any modification.
MV Agusta logo engraved with laser.
Cap for item SPSEB20R.
Site Sponsor
Discussion Starter #1,088
MV Agusta Corse CNC Transparent Clutch Cover
Compatible with: all MV Agusta 3 cylinders 2017 onwards.
Transparent housing for MV Agusta 3-cylinder oil clutches, made of billet machined aluminium.
Transparency is obtained with a sheet of Lexan resistant to shocks and temperatures, whose hydraulic seal is guaranteed by the use of a specific o-ring.
The original screws can be used for assembly.
Site Sponsor
Discussion Starter #1,089
MV Agusta Corse B3/Dragster Frame Protectors (pair)
Compatible with: B3 Y12-->Y19 and Dragster Y14-->Y19.
Left and right frame protectors made in ergal T6 7075, anodised in black, and personalized with MV Agusta Corse laser etched logo.
Site Sponsor
Discussion Starter #1,090
MV Agusta Corse B3/Dragster Carbon Clutch Cover
Compatible with: Stradale, Turismo Veloce, B3 Y16-->Y19, Dragster Y18-->Y19
Clutch cover in carbon fiber.
Site Sponsor
Discussion Starter #1,091
Jetprime CNC F4/B4 Y10 Enlarged Water Pump
Compatible with: Brutale 920, 990, 1090 Y13-->Y18, 1090 RR Y10, 1090 R Y12-->Y15, 1090 RR Y12-->Y18 and F4 1000 Y10-->Y19, 1000 R Y12-->Y15, 1000 RR Y11-->Y19, F4 RC Y15-->Y19.
This water pump has the purpose to increase the recirculation of coolant by 46% within the inside of the motorcycle.
With the original water pump and below 4700 RPM, the pump has a very slow recirculation speed which is caused by the large gap between the rotor and the pump cover.
The result of this is a huge inconvenience to the performance and comfort for anyone who uses their MV Agusta bike everyday or just for the classic Sunday ride.
For example during the summer you only need to be stuck in a traffic jam or to stop at a traffic light to cause the temperature to rise to 115-117 degrees.
To then bring the temperature back down to 90 degrees requires several kilometres of sustained speed riding which is not always possible (especially in city conditions).
Site Sponsor
Discussion Starter #1,092
MV Agusta Corse Titanium Matt Black Silencer (homologated)
Compatible with: F3 Euro 4, B3 Y16-->Y19, Dragster Y18-->Y19.
Titanium matte black conic silencer with carbon fiber end cap, racing version.
No additional ECU required, can be installed without any modification .
Only compatible with Euro 4.
Homologated for road use.
Site Sponsor
Discussion Starter #1,093 (Edited)
MV Agusta Corse Rear Sprocket Flange
Compatible with: F3 Y18-->Y19, B3 Y18-->Y19, Dragster Y18-->Y19, Turismo Veloce Y18-->Y19.
Rear sprocket flange for MV Agusta made in light alloy, machined from solid and then anodized.
Installation is easy and no changes are required, simply replacing the oem flange.
Site Sponsor
Discussion Starter #1,096
MV Agusta Corse Dragster Sachs Steering Damper
Compatible with: Dragster Y14-->Y17 Euro 4.
SACHS linear steering damper kit.
Studied for sport riders that use their bike on the road and on track.
It reduces shaking of the front wheel and get a better safety at high speed ride.
Site Sponsor
Discussion Starter #1,097
Jetprime CNC F4/B4 Enlarged Water Pump
Compatible with: Brutale 750, 910 S, 910 R, 989, 1078 and F4 750, 1000, 312 R, 1078.
Site Sponsor
Discussion Starter #1,098
MV Agusta Corse B3/Dragster Slipper Clutch Pressure Plate
Slipper clucth pressure plate made in light alloy, machined from solid and then anodized.
Plug&Play: No modification required to replace the OEM plate.
MV Agusta logo engraved.
Hi, I"m looking to buy a few parts for my new 2019 RR and was wondering if you guys have any black friday discounts coming up? looking at the getting the slipper clutch (in red) along with the clear clutch cover, the rear sprocket flange (in red) and also this exhaust. Thanks in advance for any help.
Tony
