1 - 3 of 3 Posts
Hi,
I'm A New Member To Mvagusta.net And A First Time Mv Agusta Owner.
I Started Working On My 1959? Rs150 And Need The Headlight Mounts / Fork Covers.
I'm Hoping Someone Will Be Able To Help Me Locate These.
I Will Not Be Using The Clip-ons, The Bike Has Handlebar Mounts On The Top Triple Clamp,
163 Mm Between The Triples And 30mm Forks.
Thanks,
Ellis
Hi Ellis.
All but the very first batch of 150RS's used clip-on's. The first few used handlebars that fitted BELOW the top yoke and were held on with 1/2 clamps.
If you are fitting normal bars above the top yoke then you will need shrouds from another model, possible the 235 Tevere or one of the other 125/150 varients.
There are parts out there and the UK club would almost definatly have something that would work. They would however need detail pictures etc of what you are trying to achieve.
I suggest you join the club and send them an order/request. You have to join to be able to get parts and they will not look through there stock unless you are a member either.
www.mvownersclub.co.uk will tell you all you need to know.
Hope this helps.
Dorian
Dorian,
Thanks For The Reply And Info
I Just Joined Mvowners Uk And Start Working On A Spares Order
Thanks Again
Ellis
1 - 3 of 3 Posts
