Hi all,
I am new here so first of all hi. I got a beautiful mv agusta f4 1000r from 2006. But i have a slight problem with it. One of the orginial beru went bad and damaged the ecu. I repaired the ecu and replaced the beru (cilinder 1) with a new ignition coil. For preventive maintenance i replaced the other 3 orginal berus with the same new ignition coil (its a different ignition coil then the orginial beru, photo of the new ignition coil) as that one in cilinder 1.
We fired it up and it shuts off right away. We could only keep it running when under gas but the moment you let go of the gas it shut off. We sprayed some liquid over the exhaust and the vaper stayed on cilinder 2 and 4 so maybe the firing order is wrong. Does this problem sound familair to anybody? And does somebody know the solution? Or what the orginial firing order of the cilinder should be?
Thanks in advance,
Nick
Thanks in advance,
Nick
