1 - 10 of 10 Posts
I have a Mv agusta Dragster 800 RR 2016 and ordered CNC FAST LED indicators to replace the front and rear indicators with obviously the LED INDICATORS RESISTOR kit to allow the conversion.
Originally this model has 6W indicators at the front and LEDs at the rear. Despite all the connection attempts using the diagrams supplied with the CNC kit, the indicators no longer work when I connect the resistors. Do you have a solution? Or are the 10W resistors too powerful?
You need to match the resistance to that of the original circuit, or get an adjustable intermittency (flasher relay).
Wing Nut
Welcome to the family @MartinBelanger !! Where in Canada do you reside?
Have you had your MV for very long?
Welcome to the forum.As mentioned you may not need resistors if your replacing LED with LED.
2005 F4 AGO 2017 TVL RC
You use the term 10 watt but you should be looking at the resistance. Rizoma sells 10 ohm resistors for there indicators so you might want try those
1 - 10 of 10 Posts
