1 - 10 of 10 Posts
Anyone put the a different flasher for their blinkers?
I got a new flasher with my clear tail lights that changes the speed of the blinkers for the first 5seconds (speeds them up for 5secs, then slows to normal rythm) I was curious if anyone has ever used it? do you like it?
eMoto UK said:
As far as we know there is no flasher unit on the Brutale, you need to wire in a couple of resistors.
Mine work without resistor (load equalizer) but I have regular bulbs in the front. Obviouesly enough draw just from the front ones.
I have led's front and rear (tail light) but I wired in 2x flush fits behind the mesh on my tail unit and they work just fine.And if that don't work :hitit: :)
looks awesome - any detailled pics how you installed them beheind the mesh?
Thanks for the kind comments...
Sorry no detailed pics....but what I did is really simple:I used some Motrax 'Flush micra indicators' (Bulb type) that have double sided adhesive tape on the back... then I put onto the inner plastic sub frame/inner seat cowl.... and used black silicon around them to secure them for good...the mesh hides them really well. :)
the blinkers are not blinking fast, i have a relay that came with the clear tails the is supose to speed up the blinkers for the first five seconds then slow them down to normal speeds, i was curious if anyone had any experience with this relay. my blinkers work fine right now.
The relay is for the F4, the Brutale does not have an indicator relay.
very good then. this kills my whole plan. I'm glad i didn't pull off the take to figure that out!!! Thanks for the heads up!
1 - 10 of 10 Posts
