1 - 16 of 16 Posts
Has anyone mounted the new Brutale mirrors with the built in turn signals on an older Brute?
First rule of Italian driving, "What's behind you does not concern you". Actually, I just like the look of the blinkers in the mirrors, and then I can get rid of the factory indicators.
I've actually been considering ducati hypermotard grips guards with the built in signals. I don't like the ducati mirrors but I really like the grip guards.
Steve -"come on lads , there not perfect but they are better than the previous mirrors " - which shows more how bad the previous ones were, rather than how good the new one are...
slammp - really interesting - please post if you go ahead with that.
Can't really argue with that .
In The Process
I got some nice mirrors(with indicators) on ebay for about $45 for a M-G Centauro,but they
look like they are mountable with minimal mods on my 2008 910r . I will take some pix and add details in the next few days if it works out.:
Shit mirrors are better than no mirrors.
Good mirrors are better than shit mirrors.
If given the choice of only having ONE good mirror or 2 shit mirrors, which path should one take?
The quality of these mirrors is actually pretty good,not as good as Rizoma,but fit finish and most important optics are actually quite good. They are plastic cases which may explain low cost.
I have one on and only had to drill a washer and spring a mm or 2.
Will give update after the other one is mounted and I see how good or bad the rear vision is.
I had some had high end bar ends before,but thought it screwed up the looks.
Okay I finally got them on and took some pix that I cannot figure how to upload.
The bike looks very very good to me..
The elbows still get in the way ,but about 1/3 as bad.
Vision is actually pretty good slight convex good field of vision
If anyone is interested I can give them the info .
Resize your photos.. they are probably too big to upload.
Upload of photos is simple once you figure out the photo size restriction this site uses.
Select "Go Advanced" after you choose "Quick Reply". Scroll down and find Attach Files....Manage Attachments. Click on Manage Attachments.
Here is the size limitation. Note JPG and most others are limited to 976 kb. Simply use your photo editor and resize your photo to under 976, and they upload easily.
or loadup in the gallery, no size limit there.
I'd like to know what they look like.
1 - 16 of 16 Posts
