Any advice on how to troubleshoot / replace this switch? My new Senna will not light up the neutral light on the dash even on neutral. Neutral light does work as it lights up on initial start-up self diagnostic. If I bring the kickstand down with the bike in neutral (bt neutral green light still off on the dash) bike cuts out and turn off. Also, one time (in band camp :)), coming to a stop sign I downshifted from 3, 2, and when I got to 1st bike did the same thing as when you bring the kickstand down. I'm thinking this switch is the culprit as this has happened to a dear friend of mine and my bike only has 150 miles since 2002!!!!!
I was looking for a photo of the sensor I had but can't seem to find the one I took. I did see this in my old album though and it shows the switch. It's behind the right side frame plate on the case.
Ok just cut something from the manual
As a side note don't trust the neutral light. - The MV neutral is a little flaky.
I was sitting on my bike on the weekend, bike was idling and in neutral. I must have caught the gear selector lever on the bottom of my pants and the bike pop into 1st gear. Luckly enough my hands was over the clutch.
I don't switch on the bike unless the bike is on the rear stand or I am sitting on the bike.
