Hey guys, anyone had a problem with the neutral light on their Brutale 'cos mine stays on all the time !!, but unless it's an illusion I am definitely moving.
So have any of you guys had a problem with the neutral light?
:later:
Brian1100xx
Hi Brian,
have you checked the wiring connector ,back of motor between cases and swingarm , switch is at rear of sump ,it is on F4 anyway.
I have two F4's with race shift drums ,one doesnt work and the other is on all the time.
That should be a nice bike for your neck of the woods ,think one of those underseat fuel flasks may be a good addition though.
Discussion Starter · #3 ·
Neutral light
Thanks Macmivvi I have only just got home from London and have just read your post so I shall check out the plug as you say. Looking at your reply this could be a recurring problem as your F4's have the same issue.
Ahh well it just adds ro life rich pageant :smoking: :laughing:
Thanks Mivvi
Brian1100xx
Hi Brian,
your light should not be a recurrent problem, mine are like that because of the shift drums . The light that is connected never comes on and the disconnected one is on all the time.
Sorry to mislead you .
Discussion Starter · #5 ·
Neutral light
Macmivvi that's a good pointer you gave there as you said the light that stays on has been disconnected....I wonder if the plug has come adrift or I have a broken wire :shocker:
However with the bike being less than a week old for me I shall take it back to the garage where I bought it and they can sort it out :grin: .......that's when the snow clears that is. :bawling:
Brian1100xx
