has anyone done the trick of cutting the neutral light connection to the ecu to stop the ignition retarding in the lower gears ? if so which wire to the ecu is it, and what colour ??
I know some jap bikes are retarded in lower gears but from what I hear, it is only at part throttle and when you open it up 100%, regardless of what gear you are in, it is suspose to advance it to normal timing.
I do not know about the MV's though.
I wouldn't go screwing around with anything that sends any kind of signal to the ECU. There is a huge danger of causing more trouble the any benefit. The system is designed that way. Leave it alone.
