OK, I've talked about this before, but still can't figure it out. 2005 Brutale 750S. Bike starts, idles ok, but once you try to give it throttle, it dies. I thought it might be the fuel pump/filter, exchanged it for the one in my F4, ran perfect, took it out for a 30 min ride. Tried to take it out the next day and no luck. The TPS is at 1.7, checked it with the VDSTS software. Plugs are good, air filter clean.
Did you put the fuel pump back in the F4 to see if it works in that bike?
When you say to tried to take it out the next day, did you get the same symptoms (idle but would die with throttle?)
I tried both pumps, they worked in the F4 not the Brutale, and yes same symptoms. The thing that has me puzzled, is that when I first installed the new pump and filter in the Brutale it worked fine.
Bad contacts in the kill switch? I read a while back of somebody who took one apart to investigate the source of stalling and that quality of that assembly was really sub-par.
