Hello all,
So last week I updated my fuel pump hoses . Thanks @silentservice703 for the guidance and hose. Now I see fuel dripping from the quick disconnect fittings. They are still the original plastic ones. I think now its time to update to metal ones.
I have read the thread on the fittings. As the thread is old, I wanted to double check if anyone has any recommendation on parts in 2020.
The parts I need ( Please let me know if you have any suggestions on parts below)
1. Quick disconnect Kit
Found one on ebay from Gotham cycles :
2. Grey John Guest fitting OR Square Black John Guest fittings, any suggestions on which ones are recommended ?
3. Gates 5/16 MPI fuel hose.
Let me know if anyone has all this parts together in stock. The old links dont work anymore.
Thanks in Advance,
Harshal
Call Chuck back.... he can help with everything in that department..
Interesting that they have the MV part at $99 and all the rest at less, even though they are the same thing !! MV owners willing to pay more??? Not me.
Also show it fitting a bunch of bikes it does NOT fit. Makes you wonder if they relly have their act together.
Call Chuck (silentservice703)
Reactions: Harshal
Thanks will do that
You knicked the O-ring on the quick disconnect
The correct part # is in my big sticky, it's 1 size smaller
I couldn't find the sticky. Can you please confirm the part number McMaster-Carr Part # 9464K16
Thanks,
Harshal
Thanks,
Harshal
McMaster-Carr part numbers
Fuel pump plate O-rings #9452K197
Quick disconnect O-rings #9262K141
Reactions: Harshal
Thank You Thank You
