I'm fitting a TC system on my 312R and need a 12v power source after ignition is turned on.
Looking under tank and can see fuel pump connector, and was wondering if that would be a good point to pick up on ?
Any ideas ?
power?
Spud;
For my Lambda meters I usually use the parking light circuit......
Can't use the headlight circuit on an MV .......motor must be running
How much current will you be drawing?
:popcorn:
Spud;
:popcorn:
I ended up using pins 9 - ign and 20 gnd up at the console conenctor :)
Make sure your add-on is fused.....
