1 - 11 of 11 Posts
Does your 910 come standard with a quick change carrier?
he wants to put the 910 43 tooth sprocket on his senna. will the chain pitch be an issue, as in needs a new chain too?
JamesC said:
Same chain, only length may be an issue. Not sure how many teeth you can add without a new chain.
Dunno if this helps, but 38T is stock on my bike, and a 41T runs out of adjustment on the eccentric (as the wheelbase gets too short and the chain would hit the bodywork anyway) and doesn't fit with stock chain length.
2T larger (a 40T) would've worked.
I think the formulas is... 2 teeth = 1 link!
Up 5 teeth in back, you'll need 3 extra links!
So if I wanted to raise the gearing on my 910 to reduce rpm at cruising speed, how many teeth should I drop? Will I need to shorten the chain?
Thanks.
1 - 11 of 11 Posts
