1 - 9 of 9 Posts
So I have the clear alternatives turn signals in my 2007 F4, suddenly my turn signals stopped working.. front and back. No click sound from a relay or anything. Anyone have any ideas? I'm thinking either relay or switch. Thanx for any suggestions!
BTW snapshot time :)
Pull the - pole from battery for couple of minutes, than put it back. It solved our problems.
BTW, nice pic!
I use to own Clear Alternatives. Changing the front lens cover or bulbs would not create this problem. Did you remove anything else? There are a few things to check.
1. The side metal cover under the handle bars. If you removed this cover recently, it may not be on correctly.
2. Make sure the bulbs are not burned out.
3. Turn signal relay. They sometimes go bad.
Clear Alts on my Brut blew up my CDI. Bought another CDI :cry:
If you purchased the LED version you will have to install a resistor to trick your bike into letting the signals blink.
On my first ride of this season the same thing happened. As I was riding I wiggled the right front mirror with my hand, as the bike had been up against a wall during storage. After wiggling the mirror, the signals started working again. I think the contacts in there were slightly misaligned.
1 - 9 of 9 Posts
