1 - 2 of 2 Posts
Clutch started slipping a while back, bough new oem plates opened her up and boom I find out it has an SPM slipper clutch, bought the basket clamp tool should be here tomorrow, but how do I loosen the middle part? I hope I can use the same friction plates on here too? Hmm
Automotive tire Motor vehicle Alloy wheel Automotive lighting Automotive design
F4 312rr 1078
there is nothing else to loosen up, should be ready to take it off, you have released the pressure plate so there you go.
Automotive tire Motor vehicle Product Automotive design Bicycle part
You can install standard plates, please check the value of your pressure plates ( primary spring ) as this one is responible for the stack,measure your stack height as it comes out of your bike ( 48mm, if thats the case then your plates are not worn ) check ball bearing ramps.
1 - 2 of 2 Posts
