1 - 9 of 9 Posts
I have a MV F4 2015. I notice that after a 30min riding my bike is overheating, at least it shows the temp meter. It show 3 lines up the middle point. Is this normal?, should it keep in the middle?. TIA
That is getting pretty hot, wouldn't say over heating as it'll tell you if it is. Mine goes 1 bar over the middle in town quite often but it's only a naked 800
Overheating would be all segments lit on the temp gauge with the top-most segment flashing according to the Owner's Manual. Anything less is not overheating and the fans should run as it nears the top.
antifreeze leak
Thanks for youre reply. Yesterday , the bike started to pull antifreeze when i turn off it. Thought was a leak, but ran away from the cover. Talk to my mv dealer and told me to be a failure of the cap , someone has this happened ?.
Which cap, plastic reservoir? Fluid would overflow out vent tube or if loose cap maybe there too. Or are u talking about radiator metal cap?
1 - 9 of 9 Posts
