Hi, kindly inform us if fit crankshaft from BRUTALE 1090 RR MOD 2010 to MV AGUSTA F4 312 R MOD 2007.
Attached you will find photos of crankshaft BRUTALE 1090 RR
Bent?? Donsy, are the throws different? Just curious, haven't studied on it.
a good crankshaft shop can fix it........
it gets harder to do if the crank has been nitrided.......nitrided cranks don't like being straightened
:popcorn:
I'll have to check Ed, I believe the throw is the same, the cranks between 312R and RR are the same.
I just checked, as with older MV's, the Brutale crank is different again between the F4 and Brutale in the 1078 range, and as the Brutale gets a balancing shaft on the 1090, which didn't appear in earlier models, I'd say it's different again, that's just going according to the part numbers.
So no, I don't think the 1090 crank will work in the 312R of the OP, unless someone can do a proper inspection or whatever is required to make it work, I wouldn't spend my money on it.
